dkjames's avatar
dkjames
Tutor
Sep 25, 2023
CM2000 to Rax120 connection
Is there anywhere to get a step by step instructions to wire and configure the RAX120 & CM2000 for multi-gig speeds? My modem has but one mult-gig output configured my wan port for 5G and I don't see any improvement. I can't seem to find a solution with these two devices anywhere. Thanks.
  • FURRYe38's avatar
    Go into the RAX120s web page and under Advanced Tab/Internet setup, change the internet connection from 1Gb port to the Multi-Gig port. Apply the setting. I believe the router will reboot here. Power off the CM modem for 15 seconds then back ON. The MG port LED on the front of the CM modem should turn on BLUE when it connects to the MG port on the RAX router.
