gspeaking's avatar
gspeaking
Follower
Feb 18, 2021
Cable Modem Router Compatibility
Hi all, I have a question I can't seem to figure out so I'm hoping someone can tell me before I spend some money. Currently I have the CBR40 and two satelites covering a 2800 sq. ft. I would really like to upgrade/update my system moving to WIFI6. My question is will the new Nighthawk Dual Bank WiFi 6 mesh work with the CBR40? Any help would be appreciated.
Nighthawk Dual-Band WiFi 6 Mesh System (2-Pack)
  • You could put the CBR40 in bridge mode and just use it as a modem for the new system.
  • Hi,
    Hello, generally not, Orbi products are compatible with each other, in some cases, even if they are different models, but they will not work if the router is not an Orbi router.
    Bye.
  • By the way, for example, an Orbi WiFi 6 satellite is not compatible with an Orbi WiFi 5 AC router. Consequently the network of devices Nighthawk would be separated.
  • plemans's avatar
