×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Can I Replace CenturyLink C1100T with AX4300?
birdus
I have a CenturyLink C1100T WiFi/Router and would like to completely replace it with a NetGear AX4300. Is this possible?
If so, are there some directions/instructions I can follow that will walk me through it?
If a complete replacement isn't possible, is it possible to change the C1100T over to being ONLY a bridge/passthrough? This would be a tolerable second choice.
Message 1 of 6
birdus
Re: Can I Replace CenturyLink C1100T with AX4300?
By the way, if it makes a difference, I have fiber optic. There's a box in the house (that goes from fiber to ethernet) that the C1100T plugs into.
Message 2 of 6
antinode
Guru
> [...] NetGear AX4300 [...]
   "AX4300" is a speed, not a model number.  Look for "Model" on the
product label.  RAX45?
> By the way, if it makes a difference, I have fiber optic. [...]
   It probabaly does.
> [...] There's a box in the house (that goes from fiber to ethernet)
   Thanks for that detailed description of your (unspecified) "a box".
> [...] that the C1100T plugs into.
   _What_ on the C1100T is connected to your (unspecified) "a box"?
> walk me through it?
   Other than the router documentation?  I wouldn't bet on it.  If might
help if anyone could see the configuration of your C1100T.  Possibly
interesting:
      https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-c1100z.html
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read?
   If your (unspecified) "a box" is connected to the [LAN/]WAN port on
the C1100T, then I'd guess that the C1100T is acting as a router-only,
so a Netgear router might be able to substitute for it.  I'd expect
that CenturyLink could provide the required configuration details, even
if they don't want to help you configure you third-party device.
Message 3 of 6
birdus
My Netgear router is an AX6. The box which converts the fiber to ethernet is a Calix 716GE-I.
Message 4 of 6
antinode
Guru
> My Netgear router is an AX6. [...]
   Which part of 'Look for "Model" on the product label' was unclear to
you?  The "product label" is the label on the product.
> [...] The box which converts the fiber to ethernet is a Calix 716GE-I.
   Ok.  That's an ONT.  You can think of it as a modem, if you want.
I'd guess that one of its (four) Ethernet ports should be connected to
the WAN/Internet port on your Netgear router.
   General advice: This whole Q&A thing often works better if every Q
gets an A.  Look for "?".
   Still plenty of unknown router configuration details.  You could try
connecting it instead of the C1100T, and see if its set-up wizard can
puzzle out the details.
Message 5 of 6
birdus
I'll go somewhere else for help. I'm not going to spend another second talking to an **bleep** like you.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
