× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't login into Nighthawk app on android
Wolfgar54
I can login into my router from my computer, but can't from my tablet. I even tried uninstalling it and re-installing it, no luck.
Any suggestions?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Can't login into Nighthawk app on android
Hi @Wolfgar54, welcome to the community! What error message are you getting? Please try clearing the app data and cache then check if the issue will persist.
Dexter
Message 2 of 4
Wolfgar54
That did it, although I had to proceed as if I was setting up a new device; but it is now working again.
Thanks for your help.
Message 3 of 4
DexterJB
NETGEAR Moderator
You're welcome! Glad that did the trick!
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 957 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
