- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect to WIFI Nighthawk AX$ AX3000 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Just come back from holiday and cannot connect to WIFI. Device see it, but will not connect. I cannot check if there has been a firmware up date either
Any ideas
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect to WIFI Nighthawk AX$ AX3000 4
What error are you getting when you try to connect?
Does it connect and say "connected, no internet"?
Does it not see the wifi broadcasting at all?
Does it see the wifi but not able to connect?
What modem is the router connected to?
What actual router is it? AX3000 is a speed, not a model.
Did you try factory resetting the router?
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
It is a NightHAWK AX4 AX3000- Model RAX40
You can see the router on phone but will not connect
Connected to Ethernet cable. Connected cable to my PC and worked fine
Tried factory reset with no success
- Mark as New
- Bookmark
- Subscribe
- Permalink
You didn't answer the question from @plemans about the modem/gateway. What is it?
The first thing to try, even before going anywhere near the nuclear option of a reset, is to restart the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
This can unscramble the router's brain and get it to behave itself.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
That did not work., It now says cannot get IP address when i try to connect with my phone
The modem/gataway is a virgin media one. Hub 4 /TG3492LG- VMB CM MAC ACF8CC80CA06
Any other suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That will be a modem/router. So you are piling router on router. A bad idea:
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
When you set up the RAX40, it will have tried to avoid any conflicts. Sadly, it doesn't always stick. Maybe something rebooted itself in your absence and screwed up the settings.
The preferred fix is to put the Virgin box into bridge (modem only) mode:
virgin media one. hub 4 bridge mode - Google Search
At least Virgin, unlike BT, does not block this mode.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40VUser | Count |
11 | |
8 | |
6 | |
3 | |
3 |
