× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Cannot reset AC1750
Scbartosch
Follower
Cannot reset AC1750
After a sudden unexpected shift t 10.0 subnet, I cannot change or reset this crap
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
schumaku
Guru
Re: Cannot reset AC1750
If a Netgear consumer router does get the same subnet on the WAN interface they change the LAN subnet to 10.0.0.0/24 - this happens for example if you have a cable router which is not properly configured remotely by the cabe TV company eg. following a power loss, (these devices default often to similar default subnetworks like 192.168.0.0/24 or 192.168.1.0/24) or behind another router (similar subnet on the LAN, too). Well, I don't like this idea, too - but they do it for commodity.
Use either the reset button following the fine documentation, or let the router DHCP server assign a LAN IP to a computer or mobile ... then the Web UI is certainly accessible on the assigned LAN default gateway IP or http://routerlogin.net/ or the like.
Message 2 of 2
Discussion stats
  • 1 reply
  • 935 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
