Orbi WiFi 7 RBE973
Reply
Changed to use https for admin, now can't login
Rayzorx
I just changed the Admin login to use HTTPS.  I was able to login once using Chrome and Firefox, and got the warning messages about the cert.  Now, neither one of the browsers works for logging in. They never seem to find the router.  In Chrome, I get "Site Can;t Be. Reached"  in Firefox I get
Secure Connection Failed
An error occurred during a connection to 192.168.1.1. PR_CONNECT_RESET_ERROR
Any ideas on how to resolve this?
RayK
Message 1 of 4
Accepted Solutions
Guru
Re: Changed to use https for admin, now can't login
If you can't get in with HTTPS://192.168.1.1 then you'll need to factory reset it.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Message 4 of 4
All Replies
Guru
Factory reset the router and setup from scratch.
Message 2 of 4
Rayzorx
Thanks Furrye38,
I was hoping to not have to do that, but I do have a recent saved config so it might mot be too painful.😩
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4296 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
