Orbi WiFi 7 RBE973
Reply
Chromecast cannot connect to MK63
CL7
Initiate
Initiate
I succesfully set up a home network with MK63. All devices connect except Chromecast.
I did a factory reset of Chromecast. I ran the setup in Google Home. Chromecast found the SSID but then it gave the message:
Connect to same wi-fi
Your chromecast was set up successfully but can't be found. Make sure that your mobile device and Chromecast are on the same wifi network.
Turn off AP isolation if IP isolation is enabled on your wi-fi router, you will need to disable it.
How do I do this?
Message 1 of 3
Accepted Solutions
CL7
Initiate
Initiate
Re: Chromecast cannot connect to MK63
I figured it out, I had to go into Advanced...Setup...Guest Network...
and uncheck Enable SSID Broadcast
Message 2 of 3
All Replies
CL7
Initiate
Initiate
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hi CL7 - Thanks for updating the thread as it may help others.
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2139 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
