× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connect MR60 Satellite to Orbi AX6000 router
Retired_Member
Not applicable
Does the new Orbi AX6000 router connect to MR60 WiFi6 Satellite? The existing MR60 Satellite is a small cabinet hence do not want to replace it with another Orbi AX6000 Satellite.
Thanks
Message 1 of 3
Guru
Re: Connect MR60 Satellite to Orbi AX6000 router
the orbi systems and the MK sysstems are not compatible.
They won't integrate together.
Message 2 of 3
Retired_Member
Not applicable
Thanks for taking time to reply... much appreciated.
Message 3 of 3
Discussion stats
  • 2 replies
  • 741 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
