× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connected to Modem I get 800 , when connected to RAX200 I get 400.. HELP
Bmparks03
Follower
Just wondering why my top of the line router is cutting my internet speeds. I’m not sure what to do.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Guru
Re: Connected to Modem I get 800 , when connected to RAX200 I get 400.. HELP
What ISP speeds are you paying for?
How are you speed testing? Wired or wireless? Both?
What devices do you have and are speed testing with?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 3
Guru
what firmware version are you on?
What modem/gateway are you connected to?
What site are you testing on?
Make sure to disable qos, access control traffic monitoring, and parental controls.
Then reboot and test speeds
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Discussion stats
  • 2 replies
  • 477 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
