Orbi WiFi 7 RBE973
Reply
Connecting Nighthawk AX5400 with AT&T gateway via bridge mode
Emma0225
Tutor
Hello, wanted some advice or opinions on my setup with my nighthawk AX5400 bridged to AT&T’s gateway work well? My plan will be the 1000gb plan. Please let me know if this will work well. My house is 1 floor about 2,400 square feet. Best Buy told me I would have no problems.
Thanks
Message 1 of 7
Emma0225
Tutor
Re: Connecting Nighthawk AX5400 with AT&T gateway via bridge mode
Anyone?
Message 2 of 7
Guru
each device maker calls it something different.
Are you planning on putting the netgear in access point mode or the att device in its passthrough/modem only mode?
They will connect but it just needs setting up properly to prevent a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Message 3 of 7
Emma0225
Tutor
Hello, i meant speed wise will this work ok?
Message 4 of 7
Guru
You mean the RAX50?
its a pretty rock solid router.
Sadly, its usually not the router that is a bottleneck for most peoples network but the device you're using and distance/interference.
Message 5 of 7
Emma0225
Tutor
So with my 1000gb plan from AT&T and my router I should get really good speeds right? All AT&T told me was to bridge it with there gateway and my router. Was also told to make sure to turn off wifi on there gateway.
Message 6 of 7
Guru
Usually if they're having you disable wifi, they're not putting it in passthrough mode.
If you're disabling wifi, you'd want to put the netgears IP address into the att devices DMZ
or you'd want to put the netgear into access point mode.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1470 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
