- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting cables for new router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have a Nighthawk AC1900 router (D7000v2) that has a DSL (rj11) cable plugged in to the back, I'm looking at getting a Nighthawk AX5 RAX42, this does not have the connection for a DSL cable. the question I would like answered is: I can buy a couple of adapters that the DSL cable can go in and then an ethernet cable (rj45) can go into the back of the Nighthawk AX5 RAX42, will this work or will I need a modem? Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Amazing, thank you for the speedy reply, I guess my currant router has one built in?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting cables for new router
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use the D7000v2 as a modem in front of a RAX42. If, that is, you are on the same DSL service.
Details on how to do this are in the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual:
Use the Modem Router as a DSL Modem Only
For various reasons, modem only is a better option than modem/router but DSL modem only devices are hard to get these days. Netgear stopped making them some time ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the great idea. I do have a question before I buy the RX42. You say to use the DSL router as a modem only, After setting it up as a modem, would I be able to use the AP feature within the settings? the whole reason behind me asking is the original question is because I would like to extent my wifi range. I would have the RX42 at one end of my house with the AC1900 the other.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean you want to use the D7000v2 as an AP?
In modem only mode, there is no wifi from the D7000v2.
An alternative is to use the RAX42 in AP mode.
That needs a wired connection between the D7000v2 and the RAX42.
There are ways to use the D7000v2 as a modem/router with the RAX42 as a second router.But they are a bit complicated. I have a similar arrangement with a BT modem/router in front of an MR90 router.
A better setup might be to forget about the RAX42 and to go for a Mesh router, something in the Orbi or MK range with an extra satellite or two to spread the wifi. That would give a much more manageable and reliable wifi network than trying to get two independent wifi networks to play nicely together.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Thanks again for the quick response,
I currently have a D7000v2 in the middle of my home with a vodafone modem router at the end of my home to extend the wifi (the house is hardwired to most rooms from the office). The router is hardwired and configured to the same wifi to extend it. (no AP mode, just what I found online to extend range)
The end of the house with the Vodafone router, the wifi drops in and out and very unstable and I'm forever logging back into the wifi on my phone.
I think I will go for the alternate method you suggested and use the RAX42 in AP mode or see if I can buy another D7000 and use that in AP mode. I hope that will improve over the currant set up I have. I'm happy to give that a go over buying a mesh system. (hey at least I might learn something).
Thank you for your help and answering my questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where did that vodafone modem suddenly come from? Likewise the wired ethernet.
It is a completely different arrangement from a D7000v2 in DSL mode.
Buying another one of those seems pointless if you want to get better wifi. I would start again with a more complete explanation of what is going on at your end. That means telling people just which Vodafone modem you have.
My inclination would be to dump the D7000v2 completely and add a more modern router/AP.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
