FXsr
Jul 30, 2019Follower
Connecting to IOS devices
Installed RAX 80 from the Nighthawk app.
My Macbook Air connected immediately.
My 2 Max XS iPhones did not connect.
Would appreciate suggestions/help
1 Reply
- Christian_RNETGEAR Employee Retired
Hello FXsr - Other than the iOS devices you mentioned, are other devices able to connect to the WiFi? What firmware version is currently on the router? You can try resetting your network settings on your Apple devices by going to Settings>General>Reset Network Settings.
~Christian
