a-nish
Jul 15, 2021Follower
DEV devices showing up on RAX-45
Hi all--have RAX 45 WIFI 6 router that has started to show up DEV-XX:xx:xx devices with MAC ids that are not found in an MAC databases
Please see the attached image
can someone provide the root cause and work around if any
Thanks
1 Reply
- Christian_RNETGEAR Employee Retired
Hello a-nish,
Can you provide the firmware version your router is currently on? I would recommend checking for a firmware update and reinstalling the Nighthawk app.
Christian
