× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Dead Nighthawk RAX35 - Support Ticket Open, Netgear Unresponsive
jtlynn23
Tutor
I have a RAX35 router that will not broadcast at all.  I get a power light and nothing else.
I opened a service ticket with Netgear Support at www.support.netgear.com.  I got a quick response from an agent with troubleshooting tips (including hard resets, etc etc), none of which worked.
I updated my ticket several times over the past week, asking for Netgear's recommendations and/or a replacement for my hardware and I have heard nothing.
Is anyone at Netgear support following up on tickets?
Message 1 of 6
Accepted Solutions
Guru
Re: Dead Nighthawk RAX35 - Support Ticket Open, Netgear Unresponsive
have you tried recovery via tftp?
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
another thing to check into is many don't use the proper netgear support. They google and get the wrong site/scam site.
click mynetgear at the top. register an account and the device. From there you contact support.
If that's what you did, maybe a moderator can help. @Christian_R   @olympos1625
Message 2 of 6
All Replies
Guru
Message 2 of 6
jtlynn23
Tutor
Thanks.
My expectation is that a Netgear agent will respond to the ticket that I opened specifically to address this problem.
I have an open ticket and I am simply waiting for someone in Netgear support to do their job.
Message 3 of 6
Guru
@jtlynn23 wrote:
Thanks.
And they might. Or it might take a while since they're so backed up. Or it might be never if you didn't go through the proper support channels.
Not out a whole lot to try fixing it while you wait.
Plus this is the community forums. There are a couple moderators on here but its for the whole site so they're even more backed up than support is.
Message 4 of 6
jtlynn23
Tutor
First of all, I want to send my appreciation to @plemans for the recommendation to refresh the firmware on the router-- that did the trick and the router is once again working.
As you may have read from my original posting, I was frustrated at the lack of response from Netgear's "proper channels."  I had registered the product and followed the instructions to open a support ticket.  The issue is that I received a quick response with recommended troubleshooting (none of which worked) and then Netgear Support ghosted for a week.
Glad this support community is here, and thanks again!
Message 5 of 6
Guru
@jtlynn23 Glad to hear you got it working!
the community forum sometimes (many) faster than support becaues of all the covid stuff going on. If you have further issues, let us know and we're happy to help!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1354 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
