Orbi WiFi 7 RBE973
Reply
Devices wont connect to Nighthawk RAX40 RX3000
AX2issue
Follower
I have try to connect the tv box to my router, the tv box is able to detect the wifi signal. However it won't connect to the router. I have changed the wifi setting to public without security WPA2. The tv box is able to connect to the router, when I changed it back to WPA2 security it won’t connect. In addition the tv box is able to connect via iphone hotspot. I have tried to reset the router to factory setting and it still won’t work. I wonder what is the issue with the router? Thank you.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Devices wont connect to Nighthawk RAX40 RX3000
Hi AX2issue,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 657 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
