× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Does RAX80 and RAX40 support 802.11 roaming protocol?
lvchen860217
Guide
Does RAX80 and RAX40 support 802.11 roaming protocol?(802.11k or 802.11r or 802.11v)? If RAX80 is the main route and RAX40 is in AP mode, can it achieve seamless roaming?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 7
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: Does RAX80 and RAX40 support 802.11 roaming protocol?
lvchen860217,
Yes, if the EX7700 is in AP mode, the mesh feature will work. You will need to set the SSID the same on all WiFi interfaces.
Christian
Message 4 of 7
All Replies
Christian_R
Hello lvchen860217,
The RAX80 and RAX40 currently does not support the roaming protocol.
Christian
Message 2 of 7
lvchen860217
Guide
If RAX80 is used as the main route, and ex7700 or other extender is connected through Lan-Lan (AP mode), can this combination achieve seamless roaming?
Message 3 of 7
Christian_R
lvchen860217,
Christian
Message 4 of 7
lvchen860217
Guide
Thank you for your reply.
Although EX7700 supports 802.11k, but RAX80 does not. Are there some problems when roaming from EX7700 to RAX80?
Message 5 of 7
Christian_R
lvchen860217,
There should be no problems! However, if you do experience an issue(s), please feel free to let us know!
Christian
Message 6 of 7
schumaku
Guru
Based on some early days Data Sheet where it was not listed (and initially not available) or what? The point is that Netgear does not update Data Sheets, User Manuals, ... very often.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2717 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
