vickylingtw
May 27, 2023Aspirant
DynDNS behind double NAT doesn't work
When behind a NAT the DynDNS reports the router's WAN address which is the model's private address.
Unfortunately it's not possible to turn off routing mode on the ISP's modem.
I've read it's possible to run DynDNS in web mode to report the actual internet IP but there's no way to configure it from the router setting?
1 Reply
You might try putting the netgear's ip address into whatever gateway you have's DMZ.
Should auto-forward all the info
