× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ExpressVPN on RAX80 (AX8)
STYXer
Tutor
Has anyone had any success setting up ExpressVPN on the RAX80 (AX8) router?
I see that it supports OpenVPN but I’m confused on how to get it working.
Thanks in advance.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
Guru
Re: ExpressVPN on RAX80 (AX8)
a couple things.
1. expressvpn is 3rd party firmware. You won't find help for it on the offical netgear forums
2. I don't see any supported AX routers for expressvpn currently
3. expressvpn has a list of supported models. and RAX devices aren't on there.
https://www.expressvpn.com/vpn-software/vpn-router
Message 2 of 5
STYXer
Tutor
Yes I understand all of those points, hence my question about asking for assistance. ExpressVPN supports OpenVPN and so does the AX8.
This being the case I imagine someone has figured out how to configure the AX8 using ExpressVPN configuration so that all devices connected can route through the VPN.
Message 3 of 5
Guru
So ask on the openwrt or expressvpn forum as those would be the forum for 3rd party support. NOT the official netgear forum.
Message 4 of 5
gearuser21
Did you ever find a solution to this issue?
I was wondering the same thing.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2407 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
