× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Firmware 1.2.9.52 keeps freezing every other day
CA69
Initiate
Any news on this issue? "RAX120 on Firmware 1.2.9.52 keeps freezing every other day" Same issue here including the Ethernet traffic freezes
Message 1 of 6
Guru
Re: Firmware 1.2.9.52 keeps freezing every other day
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Are you using the yellow WAN port or the Multi-Gig port for the connection between the router and your modem/ONT?
What all do you have connected to the router?
How many devices are connected at one time?
Does any of the top LEDS turn AMBER when this happens?
Does the top of the router feel extra warm or hot when this happens?
Might try a Factory reset and setup from scratch as well if this continues.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling IPv6 (auto) and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
I've had my RAX120v2 online for past week. Have not seen any any freezing or hangs since putting it online. I did factory reset mine after applying the v.52 version of FW and setup from scratch.
Message 2 of 6
CA69
Initiate
-Confess my unit was bricked during a previous fw update due to power shortage but I manage to get it running with instructions on YouTube. No issues after that until this fw. No issues to perform update latest fw during but after this fw update problems occurred. I have reinstalled the latest fw again without improvement.
-cant access that info at the moment
-cat 5e used, installed 12 year ago entire building
-using the yellow port for Internet from ONT
- Three Netgeat switches
- EAX80 Nighthawk AX6000 connected with Ethernet as in Access Point Mode with identical SSID and pw. Latest FW V1.0.1.70_1.0.2
- Two Apple TV
- Three TV
- Receiver/
- Smart home units like Philips hue, approximately 35 units in total, HomeKit, Netatmo-Doorbelll, Netatmo-Presence, Meross_Smart_Plug, IKEA , Telldus, YALE door lock, Google Nest Hub, Crome Cast
- Four video cameras
- Two NAS
- Two gaming PC
- XBOX, PS, Nintendo
- Three MacBook
- Two PC laptop
- Five iPhone
- Five IPAD
- Printer
- Two wifi speakers
-39 currently but I believe can increase
- will check
- Hot for sure but hotter I difficult to determine, 2 hrs after boot CPU 34%, Memory used 421MB/869MB, Flash usage 233/151MB, Yesterday when I checked the CPU load was 75% some hrs before ”issues” This "issues" might be heat/load issue!?
- Will try
Message 3 of 6
Guru
Please give feedback when you can.
CAT6 UTP Would be recommended since your using the yellow WAN port.
Model # of these switches please.
Might turn this OFF and test with out the EAX 80 online to see if problems still are seen with this version of FW.
- Two Apple TV
- Three TV
- Receiver/
- Two NAS
- Two gaming PC
- Three MacBook
- Two PC laptop
- Five iPhone
- Five IPAD
- Printer
- Two wifi speakers
Thats a fair amount for sure...
- will check
Please.
Yes, if the CPU is getting this high, something maybe failing or causing the higher load to go up.
 There is a Fan check feature in the debug page, please check this and enable the internal fan.
- Will try
Please let us know the results. Just reset and setup from scratch and don't use the EAX80 for now.
Enable the internal fan as well and please keep track of the CPU and memory usage.
Can you reduce the amount of devices connected if possible with leaving only most important and critical devices connected to see if the CPU load goes up after watching and tracking it?
Message 4 of 6
Guru
Any progress on this?
I had mine online for 12+ days with no freezings:
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 671 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
