× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Firmware cannot be updated on RAX45
GoldenJ
Guide
My RAX45 router is running firmware is v1.0.11.112. The Netgear prompts to update the firmware to v1.0.12.120. First, I used the Firmware Update Assistant. The process was stuck in the middle, the web page showed to wait to complete forever (over an hour). Surely during this period of time, there was no WiFi no internet during this period of time. Then I shut down the router and restarted it. The connection was recovered but firmware was still v1.0.11.112.
Later, I tried to manually update the firmware by downloading the firmware file to my computer, then uploading the firmware file through Advanced/Administration/Router Update page. Again, the process is stuck, no error message, no nothing. Surely, no wifi, no internet. I checked the router status LED. All the LED lights were lit green except that for internet. It was off. I had to shut down and restarted. Like the previous situation, the firmware was not updated, still v1.0.11.112.
What can I do to make firmware update work? Why does it not work?
Message 1 of 11
Accepted Solutions
Re: Firmware cannot be updated on RAX45
@FURRYe38 wrote:
One can skip over FW version and go directly to v.128.
Not much use if it is the update process that is failing.
But that was why I first suggested it.
Message 6 of 11
All Replies
Message 2 of 11
GoldenJ
Guide
Yes. Does it fix firmware update issue? I did not see that it will resolve the issue that FW cannot be updated. If it does, do you suggest updating FW with this FW from v1.0.11.112 by skipping v1.0.12.120?
Message 3 of 11
Guru
Message 4 of 11
Without knowing exactly what you did, and no useful error messages, it is hard to diagnose what happened.
I assume that this is the process you used:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If the "Hotfix" fails then it is the process rather than the firmware. (I assume that you tried a different download.)
One thing that can unstick a reluctant update it to reset the router before you try the update.
You could create a backup of your existing configuration before you make the plunge.
How do I back up the router configuration settings on my Nighthawk router? | Answer | NETGEAR Suppor...
Message 5 of 11
Message 6 of 11
GoldenJ
Guide
FW was successfully updated to v.128. Thanks for help!
Message 7 of 11
Well done. Always nice when the simplest option works.
Message 8 of 11
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Message 9 of 11
GoldenJ
Guide
Thanks so much again! I am curious why v.128 is called HOT FIX.
Message 10 of 11
Guru
Apparently these were high priority items:
New Features:
  • Support Speedtest server selection in web GUI.
  • Support Unicode character for attached device name and router name.
Bug Fixes:
  • Fixes the issue where USB stick can remove even files still in transmission.
  • Fixes the issue where FW cannot restore by old configuration.
Security Fixes:
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6397 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
