Orbi WiFi 7 RBE973
Reply
Guest Network extension
Swiftrunbob
Tutor
Hello
I currently have a AX12 - AX11000 Model RAX200.
I have a wireless 2.4ghz Guest Network enabled and working.
What I’d like to know/do is if I can extend that Guest Network outdoors by using a wired outdoor AP?
I’m assuming I’d need to add a switch that has a POE port for the external wired AP as my AX12 has no POE port?
Is it possible to have a wired external AP that’s dedicated as a Guest Network?
I appreciate any feedback, I might be in over my head.
Thanks
Bob
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
microchip8
Master
Re: Guest Network extension
Not possible with guest network. APs don't know about guests and the main router doesn't know if he's receiving something as "guest" or not
Message 2 of 3
Swiftrunbob
Tutor
Thanks for the information!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 810 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
