× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How can I setup parental controls on the RAX120 router
bata
It seems there is no parental control options in the Nighthawk App for the RAX120. How can I set up parental controls on the RAX120?
Thanks,
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Accepted Solutions
schumaku
Guru
Re: How can I setup parental controls on the RAX120 router
There is currently no Parental Control on any Netgear RAX router available.
You can look into https://www.opendns.com/home-internet-security/ - there are "ready-made" Family Shield (different name server IP addresses, not the standard OpenDNS ones) available for free - and configure the router accordingly.
Message 2 of 6
All Replies
schumaku
Guru
Message 2 of 6
bata
Thanks for the info. I tried the OpenDNS FamilyShield dns server addresses on the router and it didn't seem to be blocking adult sites
Thanks,
Message 3 of 6
schumaku
Guru
On it's own it won't ... business as usual, just addign these two addrreses to the router won't make it happen immediately. DNS caches mut be emptied, clients must use either the same or the router for DNS only, ... but hey, we're not OpenDNS support here.
Message 4 of 6
bata
Thanks. Got it setup with OpenDNS.
Message 5 of 6
schumaku
Guru
Be aware that when you intend to do more, the OpenDNS updater must be installed on a local system (Mac or Windows) ideally one which is "always on".
Message 6 of 6
Discussion stats
  • 5 replies
  • 7001 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
