× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How do I get my RAX80 replaced by Netgear
April1
Guide
My RAX80 keeps dropping 5G even after multiple sessions with netgear specialists. I know RAX80 is a good router but assume that few units out of millions have problems, mine is one among them.
What’s the best way to get my router replaced by Netgear? I want a good tested router directly from Netgear and don’t want to go to retailers who have possibly stocked old manufactured routers.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: How do I get my RAX80 replaced by Netgear
Hello April1,
You will need to get in contact with our Support Team regarding a possible replacement (RMA) if you have not done so already. You can contact support using the link below.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 2
All Replies
Christian_R
Hello April1,
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 942 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
