× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
I cant reset the Admin and password on my RAX15 Router
Purelight38
Follower
Is it possible to reset the security questions that are set for the router? I'm trying to reset the admin and password but it keeps telling me my security questions are wrong. My ex helped me set it up originally. I'm guessing he spelled an answer wrong. I really need help.
Message 1 of 2
Guru
Re: I cant reset the Admin and password on my RAX15 Router
Problem with the security questions is that if you don't set them up, it still asks them if you try password recovery. Your ex might not have even set them up. And if they were spelled wrong, then you dont' know the correct answer.
Basically you're back to factory resetting to get back in if you don't know the correct answers (or if they weren't setup).
to reset, push and hold reset for 7-15 seconds while its powered on. Then follow the install guide.
https://www.netgear.com/support/product/rax15.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 780 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
