× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
I have a Netgear CM1100 and Nighthawk RAX75. Is there a compatible mesh system?
jbuddy12
Is there a good mesh system compatible with my router? I don't want to buy another router to get the mesh?
Is there a less expensive option too as Nighthawk mesh is so expensive.
Message 1 of 4
Accepted Solutions
Guru
Re: I have a Netgear CM1100 and Nighthawk RAX75. Is there a compatible mesh system?
Any of them will work. but if if you're wanting ax then the EAX15, EAX20, EAX80 are all compatible.
Otherwise I usually recommend the triband EX7500, EX7700, EX8000 line.
Message 4 of 4
All Replies
Guru
Depending on how many satellites you need, there are mesh extenders.
I don't usually recommend using more than 1 extender but you can do it.
If you do, then I recommend a star configuration setup and not daisy chained.
Daisy: router---->extender----->extender
Star: Extender<-------router------->extender
Message 2 of 4
jbuddy12
Which mesh extenders work with my set up? Netgear has one that is $379.00 which is quite expensive. Had I known when I bought this, I would have gotten the Nighthawk mesh with the router all in one. Same dollars. Now I am piece mealing together it seems.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1228 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
