IamHandyAndy
Feb 17, 2020Aspirant
I just bought a NightHawk AX8 cannot logon via my desktop
Hello Gang,
So the Nighthawk is in bridge mode behind my firewall/router.
I can log onto the admin interface from my iPhone but not from my wired desktop.
They are both using the same subnet, DHCP being supplied from my windows server.
The desktop and the NightHawk connect to the same switch which is behind the firewall mentioned above.
In the manual they talk about connecting via a wired connection yet when I try I receive the following message.
"You may not be connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Router’s WiFi network. Check your current connection and try again"
Anyone know the secret on how to login from wired desktop?
TIA,
HandyAndy
IamHandyAndy wrote:I can log onto the admin interface from my iPhone but not from my wired desktop.
That's because your iPhone is connected to the AX8 wireless network, and the DNS queries are flowing over the AX8...
IamHandyAndy wrote:They are both using the same subnet, DHCP being supplied from my windows server.
In the manual they talk about connecting via a wired connection ...
The manual does talk of the wireless or wired connection to the AX8.^, further on, it's written for a consumer set-up with just a router or just the AX8 in AP mode.
The routerlogin.net / routerlogin.com DNS queries are answered by the AX8 if the query does flow over this device. If the DNS query does go over your wired network, your WIndows Server DNS will do it's job and return the public IP of the fallback page.
IamHandyAndy wrote:Anyone know the secret on how to login from wired desktop?
No secret at all.
As you have everything in your environment to make it right, I suggest to set-up a MAC-IP reservation in the DHCP server, make use of your local DNS server, and define a hostname which does resolve to the AX8 IP address. Alternate, just use the AX8 IP address in the Web browser.This is named network management 8-)
- IamHandyAndyAspirant
Yes I should have mentioned that I had set the reservation for it in DHCP
No secret at all.
As well as any other suggestions, when you approach a new network in Windows check this:
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
By default Windows sees new networks as Public and that can block some traffic.
- Network Status
- Network Profile
- Private
It is actually a domain network which is private by default.
YA I was finally able to logon using the routers ip address. Never did get routerlogin.net to work.
Thankx for all the replies!
HandyAndy
For the records: The routerlogin.net and ruterlogin.com (and similar URLs for other NEtgear products) can work only if the DNS query does pass the device, here the AX8 - the computer/device must be connected to the device wieless or to a LAN port on the device. These special URLs don't work form other systems on the network.
schumaku wrote:For the records: The routerlogin.net and ruterlogin.com (and similar URLs for other NEtgear products) can work only if the DNS query does pass the device, here the AX8 - the computer/device must be connected to the device wieless or to a LAN port on the device. These special URLs don't work form other systems on the network.
Thank You Very Much , based on that info I stuck an A record for it in my dns server and now the world is right again :>)
HandyAndy
