×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Internet Access Netgear AX5400
noelft
Having lots of issues trying to connect to my most used sites, won't let me connect on any of my PC's or Laptop anyone have an answer ?
Message 1 of 7
Re: Internet Access Netgear AX5400
Which AX5400 is that?
AX5400 is not a reliable guide to model number. Many devices come with an AC/AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Connecting how? On what?
What happens when you try?
Troubleshooting depends on  having detailed descriptions of what you are doing, what goes wrong, and what you have tried to fix things.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
noelft
It's an AX6 with WIFI 6
Message 3 of 7
That tells us even less. There are about a dozen AX6 models.
Netgear has made several "AX5400" routers.
RAX50,XR1000 and the SXK50.
As i said before, Look at the label on the device for the model number.
model number
And the other questions?
Message 4 of 7
noelft
RAX50-100NAS
Firmware Version v1.0.11.112
Message 5 of 7
This is like getting blood put of a stone.
@noelft wrote:
RAX50-100NAS
So, you have the latest firmware. But there is still some important unanswered question.
Connecting how?
On what?
All we know is that you have "lots of issues trying to connect to my most used sites".
Whatever that means, it could be down to many things.
Message 6 of 7
DamianM
NETGEAR Moderator
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
Message 7 of 7
Discussion stats
  • 6 replies
  • 549 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
