× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Internet LED on RAX38 is solid red but WiFi unaffected
HGinDC
Guide
I just noticed the status light on my RAX38v2 is solid red but my (wired) internet connection is good, as are both wifi channels. Should I ignore the red light?
Howard
Message 1 of 4
Guru
Re: Internet LED on RAX38 is solid red but WiFi unaffected
Which led is red? There's quite a few of them on there.
What modem/gateway is it connected to.
Message 2 of 4
HGinDC
Guide
It's the one designated as "Internet." The second one down from the top.
The modem is a Netgear Nighthawk CM2000.
BTW I just rebooted the router and now all lights are white, so maybe the issue has become moot.
Message 3 of 4
Guru
If it comes back, let us know. You might also log into the modem and pull its cable connections page and event logs. Maybe something dropped on the internet side and thats why the internet let showed amber.
Message 4 of 4
Discussion stats
  • 3 replies
  • 548 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
