× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Internet dropping every ten minutes, same time as lease renews.
Canthony70
Follower
I just bought the Netgear RAX42 router and every 10 minutes the signal drops for about 5 seconds and then comes right back on. The signal for the rest of the time is perfect, better than it has ever been, but as soon as the signal drops, I get kicked from whatever multiplayer game I'm playing. This problem is super inconvenient as I can't even play a full game without getting lagged out. Any suggestions?
Message 1 of 2
Guru
Re: Internet dropping every ten minutes, same time as lease renews.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you wireless or wire connected to the router?
Message 2 of 2
Discussion stats
  • 1 reply
  • 528 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
