× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Issue with external switch and AX4
Fain
Follower
Same issue as here
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX40-Not-working-with-external-Sw...
Just bought this router AX4 and connected it all up.
All is working but an external switch that works with every other router I've owned.
The switch is a TrendNet TEG-S82g 8-port
Tried multiple ports on the AX4 with no luck.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Issue with external switch and AX4
Hello Fain,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 443 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
