- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost 5G Wireless Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the RAX45 about a week ago. Updated to the newest firmware. Set up the nework and everything was working fine, until last night. My 5G wireless network disappeared. I reset the modem and it didn't work. It just did a factory reset with no luck. The 5G light is off on the router. However, the 5G network appears in the GUI. I changed the channel for the 5G network multiple times with no luck. Any ideas?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lost 5G Wireless Network
I noticed tonight in the advanced settings that it says the 5ghz network is set on Channel 0. However, in the basic page it says it is on Channel 40. Strange. Could this be a problem with the radio? I bought this at Costco, so I can swap it out pretty easily.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello tallen234,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
