× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Missing tiles in app RAX200
LML20176
Tutor
I used to be able to set up the guest WiFi and there is no longer a tile. Any suggestions?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 8
Accepted Solutions
Guru
Re: Missing tiles in app RAX200
Logging in through the browser and not using the app.
Message 4 of 8
All Replies
Guru
Have you tried it through the GUI and not using the app?
Message 2 of 8
LML20176
Tutor
Dumb question. What is GUI?
Message 3 of 8
Guru
Message 4 of 8
LML20176
Tutor
I did and was able to see the set up there. However, since it isn’t secure I prefer to not use the browser.
Just wonder why the app no longer has this function. Another issue I have is the app says the software version is the latest but when I go to the browser it says there is an update, but it times out when I try to update.
Message 5 of 8
Guru
IF there is an update, then you might manually update the FW using a wired PC and web browser. Factory reset and setup from scratch using the same wired PC and web browser. Once the router is setup and running. Try using the NH app.
Be sure to visit and post about any future RAX support needs in the RAX wifi6 series forum:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
For any NH App support needs, Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general NH router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Good Luck.
Message 6 of 8
LML20176
Tutor
Thank you!
Message 7 of 8
Guru
Message 8 of 8
Discussion stats
  • 7 replies
  • 1461 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
