×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Mr60/ms60 5g stopped showing up after update
Mtylor
So two things, when I first installed the system I was able to connect to 5g wifi. After updating, the 5g vanished and my satellite has been cutting off completely to where I have to unplug it for a while and sync it again. Anything I can do other than factory reset and hard reset
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Mr60/ms60 5g stopped showing up after update
Hello Mtylor,
You may try reverting back to the previous firmware version to see if that helps.
Christian
Message 2 of 3
Mtylor
That did not do anything sadly
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 566 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
