×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Multi-Gig port to PC?
coyote3
Guide
Can I connect via the RAX120's Multi-Gig port (5G/2.G/1G) to a PC, with say a 5G ethernet port, and get 5G?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 7
Accepted Solutions
avtella
Prodigy
Re: Multi-Gig port to PC?
Yes, it can be used as a LAN port.
Message 2 of 7
All Replies
avtella
Prodigy
Message 2 of 7
coyote3
Guide
Thank you very much, avtella!
The manual and product page didn't make that clear enough.
Message 3 of 7
avtella
Prodigy
It’s only a WAN (Internet side) port if you specifically select the 5gb port as WAN in internet settings, otherwise it acts as a LAN port. I have it connected to a 10Gbps switch (at 5Gbps link rate) which is connected to my NAS.
Message 4 of 7
coyote3
Guide
Very good to know, thanks!
Now the documentation (of it's default functionality) seems right after all.
Message 5 of 7
mrbart
so can it do dual wan now? 1gb+1gb and output 2gb on the multi-gig LAN to pc? original firmware that wasnt possible
Message 6 of 7
Retired_Member
Not applicable
I would have thought it would be able to LAG on the WAN side and LAG on the LAN side but was told it can not do this like the other AX routers.
Message 7 of 7
Discussion stats
  • 6 replies
  • 3752 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
