× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Must Login to all accounts upon PC restart
Karaptian
I just installed Netgear Tri-band AX3600 3-Pack (MK83) Nighthawk Tri-band Mesh WiFi 6 System 3.6Gbps Router + 2 Satellites
Everytime I reboot my computer, I have to re login into every site on Chrome.
Is there a setting that I need to change on my router to avoid this?
Message 1 of 3
antinode
Guru
Re: Must Login to all accounts upon PC restart
> Chrome.
   When you shut down the computer, all its network connections are
lost.  When you start it again, you must establish them again.
   No.  So far as I know, there's no setting on _anything_ which would
change that.
   You should be able to have your web browser save credentials (user
names, passwords, ...) for the sites you visit, but that may or may not
be enough to let it restore everything as it was before.  The router
certainly can't help.
Message 2 of 3
Razor512
Prodigy
The router should not impact web sessions. If you are not staying logged into websites, then it means that you likely have chrome set to not save cookies, or to clear history on exit.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 639 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
