×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
My WiFi Router
vijayeee87
My WiFi Router
After prolonged ISP side network issue or after night hours, the WiFi connection is not resuming. I checked the status of internet connection in Router it is good. But, the DHCP clients are not connected to internet. I had to reset the router and perform all the settings from the very beginning and then it works. But, cannot perform this kind of troubleshooting every or alternate days.
Can you please help me sort out the issue?
Message 1 of 5
Guru
Re: My WiFi Router
What router do you have?
What firmware is on it?
what modem/gateway is it connected to?
Do all device have issues or just wireless?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Re: My WiFi Router
You can shorten that process greatly by saving the configuration of your router along with all of those settings and the reloading it after you have reset the device.
You should do that even if the thing doesn't need these daily resets.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 5
vijayeee87
Re: My WiFi Router
What router do you have?  - AX3000 WiFi Router (RAX40)
What firmware is on it? - Firmware Version V1.0.4.102_1.0.1
what modem/gateway is it connected to? - The router itself is configured as a modem to connect to ISP network (PPOE)
Do all device have issues or just wireless? - All the clients in the LAN are experiencing issues.
Message 4 of 5
Re: My WiFi Router
You will have to explain that. The RAX40 is not a modem. As a router it needs something between itself and the Internet to work.
This will usually be a cable modem, sometimes a DSL modem, or increasingly an Optical Network Terminator (ONT). (Let's not worry about exotic satellite systems at this stage.)
Anything else is likely to come out of a "hole in the wall" that has a router at the other end. If that is what you have, then your configuration will have to reflect that.
The PPPoE bit is something that you feed into the router to get the connection through the modem.
Message 5 of 5
Discussion stats
  • 4 replies
  • 470 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
