× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NETGEAR Genie
rorton
NETGEAR Genie
Will NETGEAR Genie work with the RAX200 router?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 4
Accepted Solutions
Re: NETGEAR Genie
If you mean the Android/iOS app, no.
Which NETGEAR home router models can I manage using the NETGEAR genie app? | Answer | NETGEAR Suppor...
Try:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
If you want the desktop genie for Windows start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
Message 2 of 4
All Replies
Re: NETGEAR Genie
Try:
Message 2 of 4
rorton
Re: NETGEAR Genie
Thanks MichaelKenward, I was wanting use the monitoring functions of Netgear Genie, which I think will work with the RAX200 router. I won't be updating firmware with it
Message 3 of 4
rorton
Re: NETGEAR Genie
Monitoring on my desktop PC. I can use the Nighthawk app on my iPhone
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1819 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
