× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NETGEAR Nighthawk WiFi 6 Router (RAX120) not enough range
hanospalk
Follower
I have a RAX120 setup that used to work in my old 2 story home. We moved to a one story with the same square footage and I’m having issues with the range of the 5G network.
Would you please assist me in some solutions? Can I pick up another one and use it as a pass through? An extender? Or swap it out for a mesh system?
Thank you in advance.
Message 1 of 2
Guru
Re: NETGEAR Nighthawk WiFi 6 Router (RAX120) not enough range
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the size of your home and prior home? Sq Ft?
Building materials?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Depending on home size, you may want to look into a EAX series extender. EAX80 comes to mind.
Message 2 of 2
Discussion stats
  • 1 reply
  • 468 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
