allenga's avatar
allenga
NETGEAR Nighthawk WiFi 6E Router (RAXE300) - IoT Vlan
Hi Guys, I want to separate my smart plugs, wifi cameras on a separate VLAN.  My Cybersecurity friends said I should do it.  đꙂ
Is there a tutorial some where in this community that I could reference.
Thank you
  • FURRYe38's avatar
    Something that the RAXE router doesn't support.
    Only NG model systems that have some support for separate IoT networks is Orbi Pro 80 and 30 series and Orbi Home 7, 8 and 9 series MESH systems.
    • allenga's avatar
      allenga
      So I can't segment my network period on this device.  Advanced setting shows many options.  Thank you!
      • plemans's avatar
        You could put them on the guest network if you really wanted.
  • michaelkenward's avatar
    michaelkenward
    Do your Cybersecurity explain why you should do this? Many many people happily have IoT things working on the same network.The sky has yet to fall in.
