× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear AX1800 not blocking
aesop-riddle
I have a Netgear AX1800 WiFi Router RAX10.
I cannot block any websites. When I inquired, I was told to use the app. I do not want parental controls, I want to be able to block sites. Every router I've ever had allows me to do this with no problem.
If the router cannot do this without using parental controls through an app, then advise on a router that can.
Thanks
Message 1 of 9
Accepted Solutions
aesop-riddle
Re: Netgear AX1800 not blocking
OpenDNS did the job.
Thanks all
Message 8 of 9
All Replies
microchip8
Master
if you're trying to block HTTPS sites, that won't work due to encryption.
Message 2 of 9
From what @microchip8 says, you may be asking the impossible thanks to the rise of https.
Depending on what you want t achieve, there may be other network alternatives other than parental controls.
Message 3 of 9
microchip8
Master
Block sites at DNS level. NextDNS is a very good alternative to router blocking.
Message 4 of 9
aesop-riddle
Blocking these works fine by adding them to my Windows/HOSTS file. That's good for my computer, but doesn't help other  router clients.
Thanks for your reply
Message 5 of 9
aesop-riddle
Thanks, I'll check it out.
Message 6 of 9
aesop-riddle
Yes, I believe OpenDNS will work.
Message 7 of 9
aesop-riddle
Thanks all
Message 8 of 9
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1881 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
