- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Alexa Skill showing "Device is unresponsive".
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX200 with Firmware Version V1.0.5.132_1.0.69.
All other Alexa skills/devices work perfectly fine, but the Netgear router always shows unresponsive.
I've tried other firmwares as well.
Alexa has the Netgear skill properly added and my router is connected.
The router serial number in the description even matches correctly, and the network names show up, how "Device is unresponsive" and cannot control through Alexa.
Any ideas?
Am I missing some sort of port forwarding?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Alexa Skill showing "Device is unresponsive".
what modem/gateway is the RAX connected to?
I've seen the alexa devices/skills perform poorly in double nat situations
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also use a static IP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not trying to be rude but that doesn't help much.
If you want to get the alexa services running (not a big deal), we need full info on the setup.
Again, its because many iot devices have issues with double nat's.
If you're not worried about it working, then I wouldn't worry about it.
If it is something you want working, we need to look into what you're actual setup is and the devices connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s a completely valid request and I’m quite frustrated that i cannot provide more information. I’m quite familiar with networking myself and it’s pretty annoying not being able to access the ISPs modem as I’d be risking my life basically (and this isn’t that important lol).
The setup is ISP modem -> POE (with literally no visual identifiers AT ALL, now a letter or number anywhere -> my RAX 200.
I will attempt to contact my ISP over the phone however right now and see if perhaps they can shed some light on the equipment being used on my property.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alright, got some more information.
The ISP is using a Ubiquiti PowerBeam 5AC.
https://dl.ubnt.com/datasheets/PowerBeam_ac_ISO/PowerBeam_AC_Gen2_DS.pdf
I do not have access to this as it's on a custom built, 200 foot tower, we hire professional climbers when we need something changed, my big ass tried climbing 2 feet, and I near shat myself, so definitely do not have access to it, nor the safety equipment to attempt a journey up there lol. Oh the joys of living "in the middle of no where".
Anyways, this Ubiquiti PowerBeam 5AC is connected through to a Ubiquiti POE which is then connected to my RAX200.
Phone rep said we are avoiding a nat situation here as I am on a static IP.
Hope this helps, let me know how to proceed to continue trouble shooting this, or is my unique setup simply me being out of luck...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should also mention, this Ubiquiti PowerBeam 5AC is also pointed directly at another tower several miles away, it's not feeding some sort of wifi signal to my house or anything. I am in fact hard wired into that PowerBeam and control wifi on my property via my RAX200.
Fun Fact: with all of this, I still get a whopping 90/90 bandwith with nearly no latency, it's not bad internet at all. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats a nice setup and you're getting pretty solid speeds with your beam service.
Are you using upnp?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wish I had more to help you with.
I frequently see issues with IoT devices/NAT when using broadcast internet services.
I haven't found a good remedy for it.
A couple people were able to use their router in AP mode because their ISP was simply putting their connection on a VLAN.
Doubt this is an option for you as everything seems to be working other than the Alexa commands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh well 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
