- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk AX12
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router frequently disconnects, prompting no IP address, unable to connect to the IP for a long time
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk AX12
What firmware is on the router?
What modem/gateway is it connect to?
When it disconnects, is it wired devices, wireless devices, all devices?
Does it say "connected, no internet" or does it drop off the network entirely?
Have you tried a simple factory reset and reinstall? The RAX devices got quite a few firmware changes and have responded well to factory reset/reinstalls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ax12 is the latest firmware. I can’t connect to the network but the Wifi is connected normally. If there is no network, the router needs to be restarted for normal operation. The same problem exists when I restore the factory settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Xiong wrote:Ax12 is the latest firmware.---no its not. AX12 isn't a firmware number. I can’t connect to the network but the Wifi is connected normally----This makes zero sense. you can't connect but you can connect?. If there is no network, the router needs to be restarted for normal operation. The same problem exists when I restore the factory settings.
And the other info? LIke modem/gateway?
Please make sure to be details and precise. We aren't there to see what you're doing/done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed this router and had my laptop WIFI disconnect twice in 4 hours. If this router is junk I need to return ASAP. I changed my NTP setting, changed DNS to Google and disabled broadcast of SSID for guest. I will see what happens.
Router Firmware Version V1.0.2.136
Should I just return??? Is this product junk?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CJRATLIFF I'd recommend starting your own thread. You're on different firmware and talking different routers.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
