Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk RAX120v2
maxwell635
Follower
A couple months back i made the transition from Wi-Fi 5 to Wi-Fi 6 through the Netgear Nighthawk RAX120v2, but im having a couple issues.
Whenever im trying to download a game, lets say from Steam/Origin/Epic, my router will restart about every 2/3 GB's or so. When im not downloading the restarts dont happen as often, but the router will reset itself 2/3 times a day.
Is there a setting for this so it won't reset/restart every couple of GB's? It feels like it will restart due to bandwidth use.
Router also resets while: Any streaming service on TV (Netflix, HBO, Disney+, Primevideo, even a 'Amazon Firestick' will make the router reset itself.)
Please help 😄
Message 1 of 3
Kitsap
Master
Re: Netgear Nighthawk RAX120v2
Please help 😄
You are in the community for Wi-Fi 5 AC routers.  You should be in the community for RAX routers.  Try here:
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/bd-p/en-home-routers-nighthawk-wifi-ax...
What firmware version do you have installed on your RAX120v2?  The latest is not an answer.  Need the number for confirmation.
There is some updated/beta firmware available in the RAX community.  Look at the sticky messages at the top.
A moderator may move your message.
Message 2 of 3
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor enabled on the router by chance?
What is the first 3 characters of the routers serial numbers.
Please help 😄
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 423 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
