× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear RAX120V2 NANC
guccia123
Hi,
Had Beta firmware 1.2.8.43-RC on my RAX120V2. Now I rolled back to 1.2.8.40. Main Reason for roll back was Temperature was showing NANC and auto fan wasn't working.
After rolling back (without reset) temp still shows as NANC.
What am I doing wrong ?
Message 1 of 11
Accepted Solutions
Guru
Re: Netgear RAX120V2 NANC
Not seeing this on my RAX120v2 on v.52 FW:
There is no AUTO FAN. You can enabled it for being always ON but I believe this setting doesn't persist thru a power cycle or reboot of the router.
MS Edge is browser I use.
@guccia123 @ssssss
Message 11 of 11
All Replies
Guru
Factory reset and setup from scratch. Should clear our any lingering bad code. I believe NG disabling some of the debug items in the beta FW to help test for this reboot issue that was seen on v.40 FW. I would presume all this would be corrected and fixed in next official FW release.
Something to help with the internal fan, Install a laptop cooler fan under the router for 24/7 cooling.
Message 2 of 11
guccia123
Thanks for fast response.
When is full release expected of v43 firmware ?
And will Restore settings via cfg work or should I manually enter all configs ?
Message 3 of 11
Guru
No idea and version may not be v.43
Manually setup from scratch then save off a new backup.
Message 4 of 11
guccia123
Resetted modem and configured from the scratch. Temp still NaNC
Message 5 of 11
guccia123
Any other solution ?
Message 6 of 11
guccia123
Hello again,
any other solutions ?
Message 7 of 11
Guru
A date format is seen on mine: MS Edge
Message 8 of 11
ssssss
Tutor
It unbelievable that it take more than a year for Netgear to fix a bug for a $300 router, and it still not done yet.
Message 9 of 11
guccia123
Any fix on this problem ? I also have RAX120V2 had almost on all firmwares and Temperature Shows NaNc and auto fan doesn't work
Message 10 of 11
Guru
@guccia123 @ssssss
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1333 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
