× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear RAX200
DJScotty9000
Tutor
Netgear RAX200
I am just wondering is it normal for the Netgear nighthawk RAX200 AX11000 to disconnect from Power with cable at end that plugs in to the back router. I understand it has no central pin.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 7
Guru
Re: Netgear RAX200
I'm not sure what your actually asking here.
Some clarity as well as what your trying to do might help
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 7
DJScotty9000
Tutor
Re: Netgear RAX200
What I mean if I plugged it in sometimes the router disconnects when I move it. Just to on the safe side I bought a replacement online. I am just making absolutely sure that is not meant  to do that. I can't see no central pin inside the little plug do I have to be concerned about that I am new to Netgear Routers.
Message 3 of 7
Guru
Re: Netgear RAX200
Have you tried to read/understand what you just wrote?
Message 4 of 7
DJScotty9000
Tutor
Re: Netgear RAX200
I know sorry for the spelling
Message 5 of 7
DJScotty9000
Tutor
Re: Netgear RAX200
I am a little drunk lol
Message 6 of 7
Guru
Re: Netgear RAX200
Maybe wait for a lower BAC level and try again and we'll resume this. Right now its not just spelling thats causing the misunderstanding of what you're attempting.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 922 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
