- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear RAX50 Web UI Timeout
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I currently have a RAX50 using firmware 1.0.4.100 and my Web UI would time out after a few minutes. I would browse my settings in advanced tab and the spinning circle would stay there and eventually time out. I tried accessing through my nighthawk mobile app and it would no longer connect.
Things I've done:
Soft reset. UI would work for a few moments then timeout again
Hard Reset. Held the reset for 30 seconds and setup my network again. UI would timeout after a minute or so.
I did enable HTTPS under Web Management prior to all this starting. Ever since updating to firmware 1.0.4.100 my connections have dropped way more often than before and now I can't access my UI unless I perform a reset and even then it would eventually timeout while I'm in the UI.
Note: My internet is still working normally while I cannot connect to the router. LAN & Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear RAX50 Web UI Timeout
What browser are you using? Try MS Edge, Firefox or Opera?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
