× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear RAX54 Static Routes Don't Allow WAN Access
Compgeke
Follower
I've got a fun issue and I can't seem to actually contact support over it, despite being more of a bug.
On the RAX54 (AX5400) I can create a static route, however said route does not get WAN access.
You can ping and access anything within the LAN, however there is no WAN access going through the route. Tracert shows it dying at the router, with no ability to ping public IPs or anything.
Is it a possible to submit a bug report at all?
Message 1 of 2
Guru
Re: Netgear RAX54 Static Routes Don't Allow WAN Access
Have you tried setting a reserved ip address instead of a static route?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
