armylife4ever's avatar
Dec 03, 2020
Netgear armor cax80
Every since i got netgear armor my internet has dropped from almost a gig to about 400 megs. Does anyone know how to fix the issues? Is there new firmware updates? It is ax6000 modem
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello armylife4ever,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
