× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear's Respone to Issues Relating to IPV6 is extremley poor
JohnDiV
Star
Netgear has not solved the IPV6 issue that arose on the 1.0.2.88 and 1.0.2.92 firmeware update.  I have talked to them. They know about it ,or so they say, and have not to date came up with a fix. I challenge Netgear to be proactive and fix their junk.  So I have decided since my 30 days are almost up for return to  this RAX200 Mega Dollar Router and get a different brand gaming router with Wi-Fi6 that will run IPV6.  Maybe Asus.
Sorry Netgear you are a poor excuse of a company!!!!!!!!!!
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Guru
Re: Netgear's Respone to Issues Relating to IPV6 is extremley poor
the fix is in testing from my understanding.
But it has to be tested prior to rollout to make sure it doesn't make things worse.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 563 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
